Creating, Editing, and Deleting a PAR Level Set
  1. Select the Enterprise, zone, property, or revenue center, click Setup, and then click PAR Level Sets.
  2. Insert a record, and enter the PAR Level Set name.
  3. Double-click the record to open it.
  4. Select the CM Class.
    The CM Class list includes all Cash Management classes that you created. These Cash Management classes contain the units that are allowed within the PAR Level Set.
  5. Add a Counting Unit using one of the following methods:
    • Select Add All Units to have ECM add all defined units for the Cash Management class to the PAR Level.
    • Select Add Unit to manually add specific units.
  6. For each of the defined units, enter the quantity of units to maintain as part of the PAR Level Set for each day of the week.
    The Totals row beneath the Units table shows the cash value required for each unit quantity and day of the week.
  7. Click Save.
  8. To edit a PAR Level Set, highlight the record, change the values, and then click Save.
  9. To delete a PAR Level Set, highlight the record, and then select Delete.
    You cannot delete a PAR Level Set that is associated with one or more templates.
