Setting Privileges to Access Effectivity Groups To enable the view and edit privileges for effectivity groups: Select the Enterprise, click Configuration, and then click Roles. Insert a record for a new employee role or double-click an existing role to open it. Click the Fields tab, and then highlight the Effectivity Groups row under the EMC Modules section. In the Fields section, click the drop-down list under the Access column, and then select 0 - Editable. See Creating Roles for more information. Click Save. Parent topic: Effectivity Groups
