PreviousNext
JavaScript must be enabled to correctly display this content
Enabling Events
You need to enable events to associate transactions with
events and to use event reporting.
Select the property, click Setup, and then click Property Parameters.
Click the Options tab, and then
select 51 - Enable Events Reporting.
Click Save.
When option 51 - Enable Events Reporting is enabled , users should expect to be prompted for each newly opened
check at point-of-sales (POS) workstations. If Control Parameters
option 67 - Association of an Event to every Guest Check
is mandatory where Event is enabled is disabled, from
the Select Check Event window, click None and
then Ok to proceed with the order. If option
67 is enabled, users are required to choose an Event, or if no Event
currently exists, users receive a No events to select message prompt.
