Printing a Secondary Language on Guest Checks and Customer Receipts
To configure Simphony to print menu items in an alternate language beneath the default language on guest checks and customer receipts:
- Select the property, click Setup, and then click Property Parameters.
- On the General tab, select a language from the Select Secondary Print Language drop-down list. Select 0 - None to print only the default language.
- Click Save.
- Select the Enterprise, property, revenue center, or zone, click Setup, and then click Format Parameters.
- Click the Options tab.
- Select 52 - Print Secondary Language on Guest Checks/Customer Receipt.
- Click Save.
Parent topic: Multiple Languages on Guest Checks and Customer Receipts
