Adding Kiosk Clients
- In the EMC, add two workstation records.For the first record:
Select the 2 - Workstation Client type.
Specify the Database Update Frequency (for example, 90).
On the Revenue Centers tab, select the revenue center from the first drop-down list.
On the Options tab, Offline/Misc sub-tab, select 17 - Allow Offline Operations. This ensures the check flows from the kiosk workstation to the Check and Posting Service (CAPS) when the kiosk workstation is offline.
If you are using a barcode scanner to support ordering menu items, on the Devices tab, add a peripheral device for the scanner. Select Barcode Reader as the Type and Generic Barcode Reader as the Device.
For the second record:
Select the 3 - POSAPI Client type.
For Service Host ID, select the workstation client for the first record you created.
Select the Simphony Transaction Services version for your implementation:
For on-premise, select Enable Simphony Transaction Services (Gen 1) Location API.
For cloud, select Enable Simphony Transaction Services (Gen 2) Cloud API.
To specify a minimum and maximum check number range, on the Transactions tab, set the Minimum Check Number and Maximum Check Number values.
On the Printers tab, select the printers for Customer Receipt Printer and Guest Check Printer.
To support printing the customer receipt:-
On the Configuration tab, click Employee Classes, and open the employee class for the kiosk. On the Operator Options tab, select 0 - By Round from the Operator Type drop-down menu.
For the Revenue Center parameter, deselect 9 - On Demand Customer Receipt.
See Adding a Workstation and Printers for more information.
- Add standard Client Application Loader (CAL) packages and
the custom kiosk CAL package, and then add deployment schedules for
the packages.See the Oracle Simphony Client Deployment Guide for more information.
- Add a tag to the menu item definition under the Tags tab.
You can create new or use existing tag groups and tags. You can have
only one menu for each revenue center. Tags and tag groups are required
for the items to load on the kiosk screen.
See Configuring Menu Tag Groups and Tags and Associating a Menu Item Definition with a Tag for more information.
- Optionally, create screen look ups (SLUs) to organize tagged
menu items. You can use existing SLUs. For example, use a SLU to group
all appetizers.
See Creating Screen Look Ups for Menu Items for more information.
- Assign images to the menu item definitions.
The kiosk user interface shows the Image 1 picture on the Menu page, cart page, and as the small image anchored to the top of the menu item details page when you scroll. It shows the Image 3 picture as the large image at the top of the menu item detail page.
You can use existing menu item definitions or create new ones.
See Associating Images to Menu Item SLUs for more information. See the Networking Reference Guide for more information about hosting images.
- Set up the tender media.
For example, you can set Pay on Pick Up with the Service Total key type and SPI Default with the Payment key type. You can use existing tender media or create new tender media.
Partial payments are not supported.
You must predefine tender media for valid cards.
Guests can pay through the Simphony Payment Interface (SPI) with debit cards and credit cards such as Visa, Master Card, American Express, and Diners Club.
SPI replaces the tender based on the issuer ID in the response.
- Create the content file with the parameters that define
the order types, tenders, filters, and SLUs used by the kiosk for
each configured revenue center.
The parameter values you define in the content file must match the values defined in the EMC.
Use the following code sample as a template. Copy it to a text editor, replace the template values with your values, and then save the file as
KioskParameters.json. The table that follows the code template describes the parameters.{ "kioskParameters": [ { "kioskParameterId": 1, "orgShortName": "kmp", "locRef": "lifeworks", "rvcRef": 1, "kioskEmployeeNumber": 2, "uiOptions": { "showUpsellPage": true, "showAllergenFilter": true, "defaultCultureCode": "en-US", "selfCheckoutMode": false, "showGuestNameEntry": false, "showPostOrderInstructions": false }, "paymentDataSettings":{ "siteId": "Oracle_US_POS", "transCurrency": "USD" }, "orderTypes": [ { "orderTypeRef": 1, "postOrderInstructions": { "paidInFull": { "en-US": [ "1. Take your receipt and proceed to the pickup area.", "2: Look for the status of your order on the order status boards.", "3. Once your order number is called, proceed to the order collection station." ] }, "balanceRemaining": { "en-US": [ "1. Bal remaining.Take your receipt and proceed to the pickup area.", "2: Look for the status of your order on the order status boards.", "3. Once your order number is called, proceed to the order collection station." ] } } } ], "tenders": [ { "tenderId": 2 }, { "tenderId": 201, "useSPIPayments": true } ], "kioskMenuFilters": { "tagGroups": [ { "id": "Kiosk All Day", "tags": [ "All-Day", "Evening" ] } ] }, "categories": { "slus": [ { "sluNumber": 2, "sluImageIndex": 3 }, { "sluNumber": 4, "sluImageIndex": 3 } ], "upsellSlu": [ { "sluNumber": 8, "sluImageIndex": 1 } ] } } ] }Table 7-1 Kiosk Parameters
Name Parent Name Type Description Kiosk Parameters
KioskParameters[]
Kiosk Parameters configuration for each revenue center.
kioskParameterId
Kiosk Parameters
number
Kiosk Parameter ID.
orgShortName
Kiosk Parameters
string
Organization short name in Simphony. For example
ksk.locRef
Kiosk Parameters
string
Location reference for Property as shown in the EMC at Enterprise, Property, Report Location, Edit.
rvcRef
Kiosk Parameters
number
Revenue center reference. Object number of revenue center as shown in the EMC at Property, RVC Configuration.
kioskEmployeeNumber
Kiosk Parameters
number
Object number of the employee record used for all check operations.
uiOptions
Kiosk Parameters
uiOptions{}
Options applicable to kiosk user interface
showUpsellPage
uiOptions
Boolean
true/false
If set to true, show the upsell page only once for each ordering session.
showAllergenFilter
uiOptions
Boolean
true/false
If set to true, show the Allergens filter on the Menu page.
defaultCultureCode
uiOptions
string
Language Culture code is ISO Code Example: “en-US”
selfCheckoutMode
uiOptions
Boolean
true/false
If true, order starts from cart page. User can directly scan their menu items using the barcode scanner and check out.
If false, takes the user to Menu page. User can search for menu item, add to cart, and proceed to check-out.
showGuestNameEntry
uiOptions
Boolean
true/false
If set to true, shows the Guest name page after proceeding to check out on the Review your order page.
uiOptions
Boolean
true/false
If set to true, display configured Post Order Instructions on Thank You page based on Order Type and Paid in Full/Balance Remaining.
paymentDataSettings
Kiosk Parameters
paymentDataSettings{}
Payment settings for payment using SPI.
siteId
paymentDataSettings
string
Merchant Account Name or Number.
transCurrency
paymentDataSettings
string
Transaction currency .It is the base currency for transactions. Enter the country-specific ISO currency code.
orderTypes
Kiosk Parameters
orderTypes[]
Order types for Kiosk. Examples: Dine-In, Take Away.
orderTypeRef
orderTypes
number
Object number of Order type as shown in the EMC at Property, Descriptors, Miscellaneous, Order Types.
orderTypes
postOrderInstructions{}
Post-order instructions.
paidInFull
paidInFull{}
Post-order instructions when paid in full.
en-US
paidInFull
en-US []
Specify post-order instructions when order is paid in full in en-US language.
balanceRemaining
balanceRemaining{}
Post-order instructions when a balance is remaining.
en-US balanceRemaining en-US [] Specify post-order instruction when a balance is remaining in en-US language. tenders
Kiosk Parameters
tenders[]
Specify the list for tenders.
Tenders appear in on the kiosk user interface in the order they are specified in the parameters file.
tenderId
tenders
number
Object number of Tender Media.
useSPIPayments
tenders
Boolean
true/false
If true, for credit or debit payment, SPI replaces the tender based on the issuer Id in the response.
If false, user cannot make a payment using credit or debit.
kioskMenuFilters
Kiosk Parameters
kioskMenuFilters{}
Filters to decide which menu items are available for ordering on the kiosk. The kiosk front-end shows the first price found on the tagged definitions.
tagGroups
kioskMenuFilters
tagGroups[]
id
tagGroups
string
Enter the name of the Tag group. For example, Kiosk All Day.
tags
tagGroups
string
Enter the name of the tags associated with tag group and with menu item definitions. For example, All-Day, Evening.
tags
kioskMenuFilters
tags[]
List the name of tags that are not associated to a tag group.
categories
Kiosk Parameters
Categories{}
Menu categories to show on the Menu page. Supported category is only SLUs.
slus
categories
Slus[]
sluNumber
slus
number
SLU key number from Menu item definition as shown in the EMC at General, Touchscreen Properties where the SLU is selected.
sluImageIndex
slus
number
Image index from the SLU where the kiosk user interface retrieves the image to be shown on the user interface.
upsellSlu
categories
upsellSlu[]
Front end looks for any tagged definitions that have the SLU number configured and shows them on the Upsell page if showUpsellPage parameter is set to true.
sluNumber
upsellSlu
number
SLU key number from Menu item definition ash shown in the EMC at General, Touchscreen Properties where the SLU is selected.
sluImageIndex
upsellSlu
number
- Import the
KioskParameters.jsonfile:- In the EMC, select the property or revenue center, click Setup, and then click Content in the Custom Content section.
- Add a record and name it _KioskParameters_.
- Select 23 - Text from the Content Type drop-down list.
- Click Import from a file, and
then select the
KioskParameters.jsonfile with your values.
- Create the content file with your payment server details.
KioskServerParameters.json. The table that follows the code template describes the parameters.{ Payment : { TransCurrency: 840, SiteId: "123456789", HostURL: "https://localhost:8991", Timeout: 1000 } }Table 7-2 Payment Server Parameters
Name Parent Name Type Description Payment
Payment{}
TransCurrency
Payment
number
Enter the transaction currency ISO 4217 number. For example, 840 for United States dollars.
SiteId
Payment
string
Merchant Account.
HostURL
Payment
string
Host URL of payment device. For example:
https://localhost:<Port Number>Timeout
Payment
number
Value in seconds
1000
- Import the
KioskServerParameters.jsonfile:- In the EMC, select the property or revenue center, click Setup, and then click Content in the Custom Content section.
- Add a record and name it _KioskServerParameters_.
then select the
KioskServerParameters.jsonfile with your values.
Parent topic: Kiosks
