Configuring Major Groups
  1. Select the Enterprise, click Configuration, and then click Major Groups.
  2. Insert a record with the name of the major group (for example, Food).
  3. Enter a number other than 0 (zero) in the Report Group field.
    For example, you can enter 1 for the Food major group and enter 2 for the Liquor major group. When you enter 0 (zero), the menu item does not appear on the Menu Item Report.
  4. Click Save.
