Main and Sub Level Number Lookup (NLU)
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Double-click the transaction page on which you want the number look up to appear on the workstation.
- Insert a new button, select Function from the Type drop-down list, select either Main Level NLU or Sub Level NLU from the Function list, and then click OK.
- Click Save.
Parent topic: Number Lookup (NLU)
