Creating the Declare Waste Button
To declare waste, you need to add the Declare Waste function key to a page.
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
  2. Open the page on which to place the Declare Waste button.
  3. On the Edit tab, select the page area in which to define the Declare Waste button.
  4. Click Button to add a button.
  5. On the General subtab, enter the button name in the Legend field.
  6. Select Function from the Type drop-down list.
  7. Click the black arrow directly beneath the Type drop-down list, and then select Declare Waste.
  8. Highlight the Declare Waste button.
  9. Position and size the button on the page. Use the Style arrow to change the color.
  10. Click Save.
