Configuring Menu Item Fees Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Service Charge Groups. Insert a new service charge group or double-click the existing service charge group record. Add or remove service charges to be included with this service charge group using the Add and Delete links. Click Save. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes. Double-click the menu item class record. On the General tab, select the Service Charge Group from the drop-down list to apply to the menu item class record. Click Save. Select the Enterprise level, click Configuration, and then click Roles. Select the role, click the Operations tab, and then click the Voids/Returns subtab. Select Authorize/Perform Void of Fees. Click Save. Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design. Add the Display/Hide Menu Item Fees function key. Workstation operators use the Display/Hide Menu Item Fees function key to show or hide menu item fees on the workstation. Click Save. Parent topic: Menu Item Fees
