Allowing Employees to Enable and Disable SRM from the Workstation
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type record (for example, administrator, manager or server).
- Click the Operations tab, click the Miscellaneous sub-tab, scroll down to Miscellaneous Options , and then select 162 - Authorize/Use Quebec SRM Control Function.
- Click Save.
Parent topic: Sales Recording Module (SRM)
