Configuring a Barcode Reader
  1. In EMC, select the property, Setup tab, Workstations module, and then the Devices tab.
  2. In the Peripheral Device Configuration section, click Add, and then select the barcode reader from the Select Peripheral Device Type drop-down list..
  3. Select the COM Port Settings (if necessary), and then click OK.
  4. Repeat steps 2 and 3 to configure the barcode reader for each barcode reader attached to the workstation.
  5. Click Save.
