PreviousNext
JavaScript must be enabled to correctly display this content
Creating, Editing, and Removing Printer Groups
Select the property, click Setup, and then click Printer Groups.
Insert a printer group record, name the printer group,
and then click OK.
Double-click the printer group record to open it.
To add a printer to the printer group, click the Add link, click the ellipsis button, and then select
the printer.
You can add any printer to a printer group, regardless of
the Destination Printer option setting. You
can also add one printer to multiple printer groups.
Repeat Steps 1 through 4 for to create more printer groups
and to add printers to the groups.
To delete a printer from a printer group, select the printer,
and then click the Delete link.
Click Save.
To edit a printer group, highlight the record, change the
values, and then click Save.
To remove a printer group, highlight the record, and then
click Delete on the toolbar.
