Configuring the Barcode Scanner on the Oracle MICROS Tablet 72X
Prior to configuring the scanner, ensure that your 72x tablet
is configured with the correct Type. See Adding a Workstation for more information.
The Oracle MICROS Tablet 72x has a built-in Barcode Scanner
that can be configured as a COM3 Barcode Reader or an OPOS Barcode
Reader. Check the Device Manager to see how
yours is configured:
Honeywell N4680 (COM3) (or similar) – configured as a Generic Barcode Reader.
POS HID Barcode Scanner – configured as an OPOS Barcode Reader.
- In EMC, select Property, Setup, Hardware/Interfaces, Workstations, and then Devices.
- In the Peripheral Device Configuration section, click Add.
- For the OPOS Barcode Reader:
- For Select Peripheral Device Type, select OPOS Barcode Reader.
- For Configuration, enter Honeywell.
- Click OK, and then click Save.
- For the Generic Barcode Reader:
The Oracle MICROS Tablet 72X Setup Guide contains
more information on setting up and using the Tablet 72X, including
details on configuring changes to the barcode reader.
Parent topic: Barcode Reader
