Configuring Wireless Signal Strength Control Permissions
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type record (for example, administrator, manager or server).
- Click the Actions tab, and then click the Hardware subtab.
- Select the Wireless Monitor option.
- Click Save.
Parent topic: Wireless Signal Strength Threshold
