Adding Refill Buttons
In order for workstation operators to initiate refills for customers, you need to configure touchscreen buttons for the refill function. There are two types of refill functions: automatic and interactive.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Open the page on which to place the refill buttons.
  3. On the Edit tab, select the page area in which to define the buttons.
  4. Click Button, and then on the General subtab, select Function from the Type drop-down list.
  5. Click the black arrow directly beneath the Type drop-down list, and then select Transaction from the Type pane.
  6. Select one of the following function keys, and then click OK:
    • Refill Auto: Shows a list of refillable items on the check for selection.
    • Refill Interactive: Refills only the parent menu item and allows the workstation operator to select required and allowed condiments as necessary. Only one menu item is refillable at a time using this function.
  7. Enter a Legend for the button (for example, Refill), and then position and size the button on the page.
  8. Repeat Steps 4 through 7 and create a button for the remaining Refill function.
  9. Click Save.
