Allowing Employees to Refill Menu Items
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Double-click the role type record (for example, manager, bartender, or server).
  3. Click the Operations tab, click the Transactions subtab, and then select 186 - Perform Menu Item Refills.
  4. Click Save.
