Configuring Employee Lines
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
  2. Double-click the page on which to define the Employee Lines Area. (This is the page with enhanced table images.)
  3. On the Edit tab, select the page area on which to place the Employee Lines Area.
    Place the Employee Lines Area in the same content area on the page as the Host Command Area and tables in order for the hosting staff to access the functions and view information.
  4. Click Other..., select Table Management, and then select Employee Lines Area.
  5. Adjust the size and placement of the Employee Lines Area to ensure that it covers all enhanced tables on the page. Tables that are not covered by the Employee Lines Area do not show server assignment lines.
  6. Click Save.
