Creating Standard Dining Tables
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
 - Double-click the Front of House page on which to define standard dining tables.
 - On the Edit tab, select the page area on which to place the standard dining tables.
 - Select Other..., and then select Dining Table.
 - Move and adjust the table size on the page. Leave space between tables on the page layout to ensure visibility of indicators and table state. You can increase the grid configuration on the page from 24 (default) to 48 using the Change Grid Size link.
 - Repeat Steps 4 and 5 to create additional standard dining tables.
 - Click Save.
Parent topic: Configuring the Standard Table Management Interface
