PreviousNext
JavaScript must be enabled to correctly display this content
Uploading Data to the Target Environment
Log in to the new target environment.
Click Clone Config on the toolbar.
Drag and drop the data ZIP file to the Import Configuration
window or click the link to upload the file. Do not unzip the data ZIP file first.
Click Import Configuration File.
After the upload is complete, verify the configuration
settings in the new environment.
If the upload fails, review the error messages returned by
the clone tool, and then try the upload again.
If configuration
data exists in the target environment, the clone tool detects the
data during the upload. To overwrite the existing data with the data
you are uploading, click Erase Data & Proceed.
