Configuring the Transaction Services Default Employee
Transactions that are created and altered by the Transaction Services client must be associated with a default transaction employee in Simphony. You need to create an employee record that is not associated with a member of the staff, and is solely used for the Transaction Services client to post records to Simphony.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Employee Maintenance.
 - Click the Insert Record button to add an employee.
 - From the Add Employee dialog box, select Add Employee From Template.
 - If you created employees previously, click Employee to Copy, and then select an existing employee to copy.
 - Enter the first name and the last name of the employee.
 - Assign the employee with an operator record in the revenue center in which Transaction Services operates. Take note of the employee record number.
 - Select the Property and the Revenue Center, and then click OK.
 - Click Save.
 - Go to the POS client workstation, and run the CAL, selecting the workstation you configured through Configuring the Transaction Services Workstation Client.
 - After the CAL installation is complete, navigate to the EGatewayService directory from the workstation, open the web.config file, and then verify that the file contains the correct Api_WorkstationID value.
Related Topics
Parent topic: Transaction Services
