Changing the Appearance of Workstations Select the Enterprise, property, or zone, click Configuration, and then click Theme Assignment. Change the following settings: Default Theme: Select the default theme for the workstations. Default Palette: If you selected Edge as the Default Theme, select the color palette for the theme. Click Save. Parent topic: POS Workstations
