Send WS KDS Display Package to KDS Displays
  1. Sign in to EMC.
  2. Click the Enterprise, Setup tab, and then CAL Packages.
  3. Select All from the CAL packages tree.
  4. Click the Deployment Schedules tab.
  5. Click the Add Deployment option.
  6. Click the down arrow under Choose CAL Packages to upload to access the drop-down list, select WS KDS Display x.x.x, and then select [file name] for the version of Simphony you are upgrading to. The (xxx) refers to the version number.
  7. With the Deployment Type set to the default setting of 1 - Property/Enterprise, click the ellipsis ‘…’ adjacent to the drop-down list.
  8. Select your property from the list, and then click OK to close the Select Properties list. Click OK again to close the CAL package selection window.
  9. Verify the Action to Take column shows Install, and then click Save.
    Your KDS Displays should begin receiving the KDS Display update (or at the scheduled time).
