Property Ports
A Secure Port column is available in the Simphony EMC modules listed below. Service Hosts listen on separate HTTP and HTTPS ports for peer communications.
Access the EMC and then navigate to each module by selecting the following:
  • Location, Setup, Property Parameters, Workstations tab
  • Location, Setup, Workstations, Service Host tab
  • Location, Setup, KDS Controllers, Service Host tab
  • Location, Setup, KDS Controllers, Backup Service Host tab
  • Enterprise, Setup, Service Hosts module
  • Enterprise, Setup, Interfaces module
You cannot configure the Secure Port column (by design). Expect and allow increased network traffic from Service Hosts assigned to these secure ports.
Table 4-2 Property Ports
Service Port Number Configurable?
ServiceHost version 2
HTTP: 8080
HTTPS: 8087
Only HTTP is configurable
ServiceHost as a Service (no Ops)
HTTP: 8071
HTTPS: 8075
Print Controller
HTTP: 8080
HTTPS: 8087
IP Printer Listening
HTTP: 9100
Yes
Banquet Printing
HTTP: 9100
Yes
KDS Client (Display)
HTTP: 5022
Yes
KDS Controller Service
HTTP: 5023
Yes
KDS Backup Controller Service
HTTP: 5031
Yes
Client Application Loader (property selection screen)
HTTP: 8080
Yes
Workstations running Oracle Linux for MICROS are preconfigured with firewall rules, and available ports are limited. If this feature is needed, the firewall rules must be manually adjusted.
