Preface
Oracle Simphony is a cloud-based Point-of-Sale (POS) solution that provides business management capabilities using a single tool with vast integration capabilities to property management systems, paperless kitchen display systems, credit card interfaces, and reporting applications.
Purpose
This document provides security reference and guidance for Oracle Simphony.
Audience
This document is intended for:
  • System administrators installing Simphony
  • End users of Simphony
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at:
https://iccp.custhelp.com
When contacting Customer Support, please provide the following:
  • Product version and program/module name
  • Functional and technical description of the problem (include business impact)
  • Detailed step-by-step instructions to re-create
  • Exact error message received and any associated log files
  • Screenshots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Revision History
Date Description of Change
February 2025
Initial publication.
November 2025
Updated Property Ports in the Appendix A: Simphony Port Numbers chapter.
