PreviousNext
JavaScript must be enabled to correctly display this content
Accessing the Simphony EMC Using MFA for the First Time
To configure MFA on your Simphony system:
When first attempting to log on to the Simphony EMC, when
prompted, enter your user name in the User Name field, and enter your email address in the Email Address field.
Re-enter your email address in the Confirm Email
Address field and then click Register.
Your registered email address is written to your EMC employee
record. This email address is used to send you the one-time-password
(OTP) each time you attempt to log on to the EMC.
Access the email account you registered in step 1 and open
the email containing the OTP.
Enter the temporary password in the One-Time
Password field and then click Enter.
Newly generated OTP passwords expire and become invalid after
five minutes. If the OTP’s five minute threshold is exceeded, you
are required to log in again to the EMC to generate another OTP. After
entering a valid OTP, the EMC opens.
