Preface
Oracle Simphony Telemetry collects, indexes, and reports metrics from software components for tracking and alerting. Telemetry lets you be proactive in making operational decisions and provides insight into real-time scalable metrics of location status and performance.
Purpose
This guide provides instructions that explain how to set up and use Telemetry.
Audience
This document is intended for system administrators, Oracle Food and Beverage Consulting, and Oracle Food and Beverage Support personnel.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/.
Revision History
| Date | Description of Change |
January 2023 |
Initial publication. |
February 2023 |
Update to the Getting Started chapter. |
March 2023 |
Added the API Performance chapter. Update to the Locations and Devices chapter. |
May 2023 |
Update to the API Performance chapter. Update to the Getting Started chapter. |
July 2023 |
Update to the API Performance chapter. Update to the Locations and Devices chapter. |
August 2023 |
March 2024 |
Update to the Getting Started chapter. Update to the Locations and Devices chapter. |
April 2024 |
June 2024 |
July 2024 |
August 2024 |
September 2024 |
October 2024 |
Removal of the API Performance chapter. |
