6 Custom Browser
With this feature, you add buttons on touchscreen pages which launch web pages on the workstation. Press buttons for each URL or a button, when pressed, shows a selection dialog with a list of the available URLs for selection.
A Close button enables you to close the webpage.
The following error is shown when you attempt to access a webpage which has not been properly configured: URL is blocked. Your organization doesn’t allow you to view this site.
For your information, this is a Microsoft Edge generated error message and cannot be customized.
Key Points
This feature is only supported on workstations running Microsoft Windows which have a minimum version of Microsoft Edge 79.0.309.0.
A new Browser User has been added to the workstation for this feature.
Downloads are not allowed when using this feature.
Policies on the local machine take precedence over those of the new Browser User level.
This feature requires CAL 160 and above to work.
This functionality uses Page Visibility to restrict who can access the web page links.
