Printing a Memo Check Pick up a check that has menu items from multiple seats. Filter the check by the seat numbers for which you want to print the memo check. See Filtering a Check by Seat Number for instructions. (Optional) Tender the check using the guest’s payment method. Press the Print Memo Check function key. Related Topics Seat Filtering and Memo Checks Parent topic: Guest Checks
