Assigning Components to a Menu Item
- Select the property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
 - Double-click a menu item definition record to open it, and then click the Components tab.
 - Click Add, click the ellipsis point (...) button from the Components column, select a component, and then click OK.
 - Repeat Step 3 to add all components that belong to the menu item.
 - Click Save.
Parent topic: Menu Item Components
