PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Order Chits for Dining Courses
Select the revenue center, click Setup, and then click Order Devices.
Double-click a KDS order device, and then click the Options tab.
Select the following options:
17 - Print Course Header: Select to
include the course header on the KDS chit display.
20 - Show Previous Course Indicator:
Select to show an icon on order chits from any course other than the
first to indicate that a previous course exists for this check. This
option is for systems using KDS Coursing functionality that have the Display Next Course after Previous Course Complete KDS
Controller option set. This feature is not supported with DOM.
