Configuring KDS Displays to Show One Course at a Time
If the property uses dining courses, you can configure the KDS to show only one course at a time. That is, menu items from course 2 appear on KDS Displays only after menu items from course 1 are bumped.
  1. Select the property, click Setup, and then click KDS Controllers.
  2. Double-click a KDS controller, and then select 2 - Display Next Course after Previous Course Complete on the General tab.
    The Enterprise Management Console (EMC) enforces mutual exclusivity between RVC Parameters option 50 - Enable Dynamic Order Mode (DOM) and option 2 - Display Next Course after Previous Course Complete. Option 50 cannot be enabled for a revenue center if its associated KDS controller has option 2 enabled. Likewise, option 2 cannot be enabled on a KDS controller if it is assigned to a revenue center with option 50 enabled. A KDS Controller with option 2 enabled cannot be assigned to a revenue center with option 50 enabled. See Enabling and Disabling DOM for more information about option 50.
  3. Click Save.
