Configuring a KDS Order Device
- Select the revenue center, click Setup, and then click Order Devices.
 - Select an order device record (1–32) for the KDS, and then double-click the record to open it.
 - On the General tab, select 1 - Remote from the Device Type drop-down list, select 1 - KDS from the Primary Device Type drop-down list, and then select the appropriate KDS Display record from the Device drop-down list.
 - If you have a backup printer, select it from the Backup Device drop-down list.
A configured printer for a backup device only works for a KDS when the KDS Controller or Service Host is down; it does not work when the RDC is offline or powered off.
 - From the Order Device Redirect drop-down list, select the same KDS order device you modified in Step 2.
 - From the Condiment Sort Type drop-down
list, select how to sort the condiments on the order chits. Condiment
sorting only works if you have set Menu Item Classes option 30 - Sort Condiments by Print Group for the parent menu
items.
No Condiment Sorting: Select to list condiments in the order in which they are entered to the check by the workstation operator. However, allowed condiments will sort in the order assigned in Condiment sets, if configured.
Sort Allowed Condiments: Select to sort only allowed condiments based on the print group. The sort order configured for allowed condiments in Condiment Sets is discarded. If required condiments are ordered in between allowed condiments, the required condiments will remain in the same position in which order they were ordered.
Sort all condiments: Select to sort all condiments based on the print group, regardless of condiment type.
 - From the Menu Item Printing drop-down
list, select which items to route to this KDS:
All Items: Select to route all menu items.
Only Items with Condiments: Select to route only menu items with condiments.
Only Items without Condiments: Select to route only menu items without condiments.
 - Click the KDS tab, and then configure
the following settings as required:
Table 3-10 Order Devices KDS Fields
Field Description Course 1 First/Second Alert Timeout
If you are using the KDS Coursing function, enter the time in seconds when course 1 items display the first alert and second alert respectively.
Chits showing a first alert are shaded yellow, while the chits showing a second alert are shaded red.
Other Course First/Second Alert Timeout
If you are using the KDS Coursing function, enter the time in seconds when any course except course 1 displays the first and second alert respectively.
Primary Runner Chit Printer
Select a printer where runner chits print when orders are bumped from the KDS device.
Backup Runner Chit Printer
Select a printer where runner chits print when orders are bumped from the KDS device if the application cannot establish communication to the primary runner chit printer.
Send To Panel
Select the panel where orders sent to this device should display.
This field is only active when the order device contains more than one panel.
DOM Type
Dynamic Order Mode (DOM) contains more information.
Add Sort Rule
This feature is only supported with DOM.
Modify Sort Rule
Void Sort Rule
Add Highlight Scheme
Modify Highlight Scheme
Void Highlight Scheme
Beep On New Order
Select the sound type to emit when an order is received on the device. If you select 2 - WAV File, the application uses the default WAV file set for the operating system.
Display New Order Notification
Select this option to make new orders flash when they appear on the KDS Display.
This feature is not supported with DOM.
New Order Notification Timeout (seconds)
Enter the length of time in seconds newly added items should flash on the screen. When this threshold is reached, items appear normally.
This field is only active when you select Display New Order Notification.
Beep On Prioritize (Increase)
Select the sound type to emit when an order is assigned a priority and also when the priority of an order is increased on the order device. If you select 2 - WAV File, the application uses the default WAV file set for the operating system.
Beep On VIP
Select the sound type to emit when a VIP order is received on the device. If you select 2 - WAV File, the application uses the default WAV file set for the operating system.
Beep On Rush
Select the sound type to emit when a rush order is received on the device. If you select 2 - WAV File, the application uses the default WAV file set for the operating system.
KDS Display Backup
Select the backup order device for the KDS Display. The backup order device must be another KDS Display linked to the current revenue center’s KDS Controller.
If the POS client cannot communicate with the KDS Controller, orders are sent to the backup device configured on the General tab.
If the POS client can communicate with the KDS Controller, but the controller fails to communicate with the desired KDS Display, orders are sent to the backup order device.
If the device has multiple panels defined, backup chits always go to panel 1 of the physical device to which the backup order device is linked.
Attention:
For locations utilizing the Production Lane feature, the KDS Backup Device selected from the drop-down list in the Order Device module, must exactly match the same configuration as the primary KDS Display it is backing up (including all KDS options and any existing Lane assignment).Lane
The Lane value is used to determine which Lane or grouping of order devices an order device belongs to. Two production lanes are supported. Zero is the default setting.
In order to configure this field, you must associate order devices in the Associations section.
See Configuring Production Lanes for more information.
Workflow
The Kitchen Display Workflow value is used to determine where an order shows first, and once complete, where it shows next, and so on. Leaving this setting with a zero value dictates the order always shows unless the order is required to be claimed, and if so, the order shows only after it is claimed. If two order devices have the same workflow value, they show the orders at the same time. If order device A has a higher workflow value than order device B, the system only shows orders on order device A, and once it is bump/done, it then shows on order device B. This field supports values from
0to999(the default setting is0).Links
The Links feature allows a user to bump/done an order at one prep station and have it simultaneously bump/done the order from all linked prep stations. The feature effectively mimics Expo behavior at the Prep station level.
The process works well in establishments with a large and diverse menu. In a quick service restaurant (QSR), where volume is high, but the range of menu items is small, subdividing the prep stations isn't simple. More often than not, several kitchen staff are working on the same set of items. In this situation, it makes sense for multiple prep stations to see the same orders. As staff members become available, they prepare and done the next order on the display. As soon as it is complete, it is removed from all linked prep stations.
To work correctly, the Bump Marked Items option (from the Options tab) must be the same (that is, checked or cleared) for all KDS devices linked to the same order device.Linked devices may be included as part of a kitchen theme.
To configure this section, click the Add link.
From the drop-down lists, specify which KDS order devices this order device's bump bar/toolbar controls. Each order device can control up to 8 KDS devices. Only preps may be linked to other prep stations. Click Save.
Associations
The Associations feature is required to pair KDS display order devices to be used along with the Lane field setting for the purpose of using the Lane Claim and Lane Push functions. If order devices have a lane and associated device configured, the system shows the suborders on both lanes and the kitchen staff are required to claim the order before performing other actions. When performing a Lane Claim on an order, the order is removed from the other lane. Lane Push moves a previously claimed order to another lane.
Important:
You can only associate Prep Stations to other Prep Stations and Expo Stations to other Expo Stations. When adding KDS order device Associations to the Order Devices module, you need to assign a production Lane to each order device you want to associate with each other, and these order devices need to be assigned differing Lane values (Lane 1 or Lane 2). You cannot associate one KDS order device with another which has zero assigned in the Lane field.
When you assign Lane or Workflow values, you must do so at the same time and prior to saving the changes. Order device associations must also be performed at this time. After the entire configuration is complete, click Save.
When you claim an order, all of its suborders are claimed for that lane. Once claimed to a lane, an order can be unclaimed (or restored to its original state) by using the Lane Claim function again. If any of the suborders have been bumped, you cannot unclaim the order. If the previously-bumped suborders are recalled (using the Recall function), the order can then be unclaimed or restored.
Production Lanes can be used with kitchen themes to create themes to allow switching between production lanes or not using Lanes at all. The Workflow feature can also be used with kitchen themes.
See Kitchen Themes for more information.
 - Click the Options tab, and then
select the appropriate KDS options as described in the following table:
Table 3-11 Order Devices KDS Options
Option Description 1 - Enable KDS Consolidation
Select this option to consolidate identical items with different modifiers onto one line, preceded by the quantity on the KDS Display.
KDS Consolidation is not supported with DOM or with any DOM KDS chit layout style, including option 35 - Use Delivery Chit Format for Runner Chits.
2 - Sort Voids to Top (not DOM)
Select this option to sort voided items to the top of the display.
3 - Single Item Per Sub-Order
Select this option to show every item on an order on its own chit. This option is enabled for KDS Menu Item Prep Timing.
If you are using KDS load balancing, Oracle Restaurants recommends you set this option for the most equal distribution of menu items.
4 - Print on Prep Done
Select this option to print a runner chit when the order is marked as Done at a Prep Station. Only items from this Prep Station print.
5 - Print on Expo Done
Select this option to print a runner chit when the order is marked as Done at the Expo Station.
6 - Print on All Prep Done
Select this option to print a runner chit when an order is complete at all Prep Stations and before the order is bumped from the Expo Display.
7 - Sort by Seat
Select this option to sort check detail by seat number. Deselect this option to have items display in the order in which they were ordered.
8 - Re-sort when All Prep Done
Select this option to cause the Expo Display to re-sort a chit to the beginning of the list on the Expo Display, when all Prep Stations have marked the chit as Complete.
This option only applies to Expo Displays.
9 - Display Subtotal
10 - Do Not Display Voids
11 - Display Menu Item Count
12 - No Expo Done Before Paid
13 - Unconsolidate Items After Condiment Entry
Select this option to unconsolidate multiple quantities of menu items if condiments are selected for each item. This option only works when using DOM or when 1 - Enable KDS Consolidation is set for the order device.
14 - Multiple Condiments Per Line
Select this option to display condiments in a continuous line on each order chit. Deselect this option to print each condiment on a separate line beneath the referenced menu item.
To compress the condiments into a single line, you must not print condiments in red.
15 - Display New Order Notification
16 - Expo Done Exempt
Select this option to prevent an Expo Station from marking a suborder as Done, when it is marked as Done on another Expo Station.
17 - Print Course Header
KDS Configuration for Dining Courses contains more information.
18 - Do Not Consolidate
Select this option to print identical items separately if they are posted separately. Deselect this option to consolidate identical items onto one line, preceded by the quantity.
Menu items with condiments do not consolidate. Options 7 - Sort by Seat and 1- Enable KDS Consolidation override this option. To disable consolidation, you must select this option and then deselect 1 - Enable KDS Consolidation
The output format depends on the settings of 7 - Sort by Seat and 18 - Do Not Consolidate.
19 - No Prep Done Before Paid
This feature is only supported with DOM. See Dynamic Order Mode (DOM) for more information.
20 - Show Previous Course Indicator
21 - Disable Double Touch Bump
Select this option to prevent KDS users from bumping an order by touching a chit twice on the display.
22 - Match Voids with Order Chits
Select this option to have voided order chits appear directly in front of the order it relates to.
23 - Sort by Print Group
Select this option to sort menu items based on the print group. If a print group is not assigned, items print according to their record number.
Option 7 - Sort by Seat overrides this option.
24 - Print Check on Expo Done
Select this option to automatically print the guest check once the corresponding chit is marked complete on the Expo Display.
25 - Alerts Exclude Prep Time
Select this option to exclude menu item prep times from alert time calculations.
26 - Bump Marked Items
Select this option to allow KDS users to bump marked items and orders from this display.
If option 12 - No Expo Done Before Paid or 19 - No Prep Done Before Paid is also selected, KDS users cannot bump marked items or orders until the check is paid.
27 - Suppress Check Total
28 - Use Deli Chit Format for Runner Chits
Select this option to override the traditional runner chit layout with the deli chit layout, which prominently shows the order number.
29 - Item Print on Item All Prep Done
Select this option to allow runner chit printers to print a chit for each individual item by order type.
The chit prints when the cook bumps the item from the KDS Display. If the item routes to multiple Prep Stations, the runner chit prints when it is bumped from the last KDS station. If runner chit printers are assigned by the KDS order device, chits print to the runner chit printer assigned to the last KDS the item was bumped from.
You must also enable Order Types Parameters option 9 - KDS Allow Item Print on Item All Prep Done for this feature to work. This feature is only supported on Prep Stations.
30 - Suppress Guest Check ID on Runner Chits
Select this option to prevent the guest check ID from appearing on runner chits printed from this order device. When selected, the guest check number prints on the runner chits instead of the check ID.
31 - Always Show Quantity
Select this option to show the quantity for every condiment ordered, even if the quantity is 1. When set, condiments must be added to the check singly, that is, without using the on screen numeric key pad for multiple condiment orders. You must deselect option 1 - Enable KDS Consolidation for this feature to work.
When deselected, the quantity is implied from the item preceding it on the order chit.
32 - Remove Original Chit When Item Voided
When an item is voided on the POS, the associated item chit is removed from the KDS. Usage considerations:-
DOM does not support this option.
Expo/SOS KDS displays are not supported for the use of this option.
Expo Load Balancing environments are not supported for the use of this option.
Selecting 3 - Single Item Per Sub-Order activates this option.
Selecting this option activates 33 - Hide Void Chit When Item Voided and 34 - Show Void Chit Even if Item No Longer in Production.
When option 22 - Match Voids with Order Chits is enabled and the KDS Controller is reloaded, stopped, or started, the VOID chit does not remain in its location if its original chit has been removed manually or automatically. The chit moves to the front of the queue. Remote View shows all voids at the front of the queue.
When an item is voided on the POS, the associated item VOID chit is hidden on the KDS. Usage considerations:-
Selecting 3 - Single Item Per Sub-Order and 32 - Remove Original Chit When Item Voided activates this option.
The void chit shows for an item which has been bumped from the KDS before being voided on the POS. Usage considerations:-
When option 22 - Match Voids with Order Chits is enabled and KDS Controller is reloaded, stopped, or started, the VOID chit does not remain in its location if its original chit has been removed manually or automatically. The chit moves to the front of the queue. Remote View shows all voids at the front of the queue.
Select to print a runner chit, which can be used for labeling individual items in an order. When selected, the Delivery Runner Chit format will apply to all Order Types.
Option 1 - Enable KDS Consolidation is not supported when using option 35.
36 - Disable Chit Notifications
Select this option to disable visible chit notifications on Expo and SOS devices. New order notifications are not affected.
37 - Automatically Remove Orders on All Prep Done
Select this option to automatically remove orders on this device when all preparation is done.
 - Click Save.
Parent topic: Basic KDS Configuration
