PreviousNext
JavaScript must be enabled to correctly display this content
Linking Production Items to KDS Displays
Select the property, click Setup, and then click KDS Displays.
Double-click a KDS Display record to open it.
Click the Production Item tab.
From the KDS Production Location drop-down list, select where to place the production bar on the
display.
To set the production bar to appear above the order chit, select 1 - Top.
To set the production bar to appear below the order chit and
above the KDS toolbar (if used), select 2 - Bottom.
From the KDS Production Columns drop-down
list, select the number of production items to show per line or production
bar. When possible, the KDS displays the maximum number of items in
each bar. If there are not enough items to fill the last bar, the
remaining items are evenly distributed across the line.
From the Production Items section, click Add, select a production item to appear on the KDS, and then select
its Persistence:
Static: Select to always show the production
item on the KDS Display.
Dynamic: Select to show the production
item on the KDS Display only when it has an item count.
Repeat Step 6 until all of the production items to display
on the KDS appear in the list.
