PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Multiple Panels on a KDS Display
Select the property, click Setup, and then click KDS Displays.
Double-click the appropriate KDS Display record to open
it.
Click the Display tab.
From the Panel Layout drop-down
list select whether the panels appear side-by-side or one on top of
the other.
Click Add below the Panel Configuration
table.
In the Proportion column, enter
the ratio of the display area that the panel will occupy.
From Chit Columns, select the number
of columns to use in the panel for order chits.
From Chit Rows, select the number
of rows to use in the panel for order chits.
The Chit Rows column only becomes enabled if you select Horizontal or Vertical as the Serpentine Mode for order chits from the Chit Display
Options section on the Display tab.
To see a graphical representation of the panel proportions,
click Preview.
Repeat Steps 5 through 8 to add more panels to the display.
You can configure up to nine panels on the display.
