PreviousNext
JavaScript must be enabled to correctly display this content
Configuring the KDS Toolbar
Select the Enterprise, property, or zone, click Setup, and then click KDS Tool Bars.
Insert a KDS Tool Bar record if
it does not exist, and then double-click the record to open it.
(Optional) Enter the Button Height and the Button Width, and then select the Background Color for the toolbar.
If you do not configure a button height and width, KDS uses
the default value of 60 pixels.
To configure the KDS toolbar with Oracle Hospitality default
functions, click Create Default.
To configure the KDS toolbar with specific functions:
Click Add, select the Function, enter the Legend for
the toolbar button, and then if enabled, enter the Parameter for the selected function.
The Parameter field only becomes active when the function
requires a parameter. For function Remote View Specific, enter the
record number of the KDS Display that you want to remotely view in
the Parameters field.
(Optional) Select the Background Color for the toolbar button, and then select the Legend Color.
Repeat Steps 5-a and 5-b to add all appropriate KDS
toolbar functions. KDS Bump Bar and Toolbar Functions contains a list of all
KDS toolbar functions.
To reposition the function buttons on the toolbar, in the
column with the number sign (#), click the position number of the
function, and then click the up and down arrow buttons to move the
position.
