PreviousNext
JavaScript must be enabled to correctly display this content
Creating a Kitchen Theme Period
Select the revenue center, click Configuration, and then click Kitchen Theme Period.
Insert a new kitchen theme period record, and then double-click the record to open it in form view.
Select the appropriate Kitchen Theme for this period, or select 0 - None to use the default configuration.
Click the Effectivity tab.
(Optional) Select the Start Date and the End Date for the kitchen theme.
When both the Start Date and End Date are disabled, the record is considered active.
Select on which days of the week the kitchen theme is active, and then select the Active Start Time and the Active End Time for the theme.
Only one kitchen theme can be active at a time. Do not overlap the Active Start Time and Active End Time settings.
When both the Active Start Time and Active End Time are disabled, the record is considered active all day. When the Active Start Time is disabled, the record is considered active from midnight. When the Active End Time is disabled, the record is considered active until midnight the next day.
