Audit Trail Search Results
Figure 4-2 Audit Trail Search Results Tab
After running a search, the Results tab becomes active and the results of the search are displayed. The records display in a Table View-like grid, allowing sorting and filtering. By default, the grid displays the most recent changes at the top of the list. The columns are described in the following table.
Table 4-1 Audit Trail Search Results Column Names
| Column Name | Description |
Shows the Audit Trail Record ID of each Audit Trail Entry. |
Audit Time |
Shows the time of the change or activity. |
Emp # |
Shows the employee number of the employee who made the change. If the change was made by an employee who is now deleted, a “0” is assigned to that record. |
Emp Name |
Shows the name of the employee who made the change. If the change was made by an employee who is now deleted, the database ID 1234 appears (where 1234 is the Database ID of the deleted employee). |
Prop # |
Shows the property number, if any, where the change was made. If the property of the change is deleted, this column shows “- 1.” If the change was an Enterprise level change, this column is blank. If the change was made in a revenue center, this column shows the property to which the revenue center belongs. |
Prop Name |
Shows the name of the property, if any, where the change was made. If the property was deleted, this column shows “??? 1234” (where 1234 is the database HierStrucID of the deleted item). If the change was made on the Enterprise, this column shows “(Enterprise).” If the change was made in a revenue center, this column shows the name of the property to which the revenue center belongs. |
RVC # |
Shows the revenue center number, if any, where the change was made. If the revenue center of the change was deleted, this column shows “-1.” If the change was an Enterprise or property level change, this column is blank. |
RVC Name |
Shows the name of the revenue center, if any, where the change was made. If the revenue center was deleted, this column shows “??? 1234” (where 1234 is the database HierStrucID of the deleted item). If the change was made on the Enterprise or property level, this column is blank. |
Application |
Shows the application where the change was made. The list includes different applications within Simphony such as EMC, PMC Procedures, PMC Reports, and others. |
Module |
Shows the module, if any, within the application where the change was made. This column typically displays an EMC Module name. When the audit record displays a PMC Report, this column displays the name of the report that was taken. |
Operation |
Shows the type of operation that occurred. |
Obj Num |
Shows the object number of the record that was changed. If the audit record is a PMC Report, this column displays the Autosequence Number that was run. |
Field |
This column generally applies only to changed records and shows the field that was changed. For example, if a Discount's option 1 is changed from ON to OFF, this column shows Option 1, ON = Open; OFF = Preset. |
Old Value |
This column generally applies only to changed records. When a field is changed, the Old Value shows the value of that field before the change. |
New Value |
This column generally applies only to changed records. When a field is changed, the New Value shows the value of that field after the change. |
Dist Source |
When a user performs distribution, this column shows the property or source revenue center from which the original record was distributed. |
Comments |
Shows comments added to the Audit Trail record. Some applications may record comments to help clarify the change or activity being audited. |
Save or copy search results
To save the results, click Save to Disk, select the directory, and then click Save.
To copy the results to another application without saving them, click Formatted Results, and then click Copy.
