30 Banquet Guest Check Printing
A banquet guest check is used to present a specially formatted guest check for customers. Although it can be used anywhere, the banquet guest check is intended for use in a banquet environment. In this environment, additional information can be reflected on a guest check, such as the event name, address, contact information, name of the room where the event was held, names of the maitre’d and catering sales manager, and the event’s serving period.
One format of the banquet guest check is available, using an 8.5 x 11 page output which prints on a custom page printer.
Figure 30-1 Example of a Printed Banquet Guest Check
This figure shows an example of a printed banquet guest check as formatted on 8.5 x 11 printer paper.
