Holding and Sending Items to Order Devices
The following table describes how to configure the workstation to hold and send menu items on open guest checks to order devices.
Table 23-4 Configure Workstations to Hold Items on Guest Checks
Task More Information
Enable option to hold items on guest checks and add touchscreen buttons
Setting the Hold and Fire Option
Enable workstation notifications for held menu items when tendering
Setting the Hold and Fire Tender Notification
Configure workstations to remind workstation operators of checks with items on hold after signing into the workstation
Setting a Reminder for Items on Hold
Configure guest checks with items on hold to end current service round and add touchscreen buttons
Setting Checks with Items on Hold to End Current Service Round
Configure how to handle items on hold when closing checks
Setting Check Handling with Items on Hold when Closing Checks
(Optional) Configure Check Screen Look Up (SLU) to display checks with only held items
Configuring Check Screen Lookup (SLU) to Show Checks with only Held Items
