Skip
Decide on your menu. Skip supports up to two menus.
Decide on unique tag names for the menu or menus.
Plan the list of menu items.
Determine menu availability. For example, will the menu be available only on weekdays between specific times?
The menus can have multiple categories but must have at least one category. A category is a group of similar menu items. For example, you can have a lunch menu with categories for salads, sandwiches, and desserts.
In Simphony, a category corresponds to a SLU. Each category needs its own SLU.
Skip supports a maximum of 100 SLUs. -
Decide on an image to display for each menu. This is optional.
Consider the following characteristics of each menu item:
Customer-facing menu item name
Customer-facing menu item description
Menu item image that meets the following specifications:
JPEG or PNG file format
Pixel size of 1920 x 1080
Aspect ratio of 16:9
All images are manually verified by Skip and will not appear immediately on the ordering site. -
Menu item price
Allergen classes
Consider the display of menu items on delivery platform ordering sites and kiosks, and determine whether the following are needed:
Price sequence level filter
Condiment group filter
Image slot
SLU slot
