Awarding Algorithms
The better deal always wins with automatic discounts. For example, if you set both Buy One DVD Get One CD For Free and Buy One DVD Get One Car For Free, the application discounts the price of the car to $0.00 because this is a better deal than receiving a CD for $0.00.
When using automatic discounts, Simphony detects the presence of discountable menu items on a transaction, and then performs algorithms to determine which discounts are applied and which items receive a discount. The following two types of algorithms determine the discount:
Table 15-4 Awarding Algorithms
| Awarding Algorithm | Description |
Best Deal for Customer |
If two discounts can be applied to a check and one yields a higher discounted amount, that discount is said to give the best deal. If two discounts can be applied to a check, and the order in which they are applied yields a different amount, the ordering which gives the customer the highest discount is said to give the best deal. Each automatic discount type provides the best deal for the customer,
which means that the workstation scans all menu items and determines
the largest discount to apply. In this example, a common best deal
scenario is described as follows:
In this example, the higher-priced shirt is discounted, so the customer receives a total discount of $20 instead of just $15. This is the calculation for all automatic discounts and you cannot configure it (except for Quantity Threshold Discounts). By default, the workstation considers all menu items on the check and all discounts that can apply, and creates the largest discount possible for the customer. |
Best Deal for Merchant |
You can configure Quantity Threshold Discounts to provide the best deal for the merchant, which means that the customer receives the lowest possible discount. Some jurisdictions require this configuration. |
Figure 15-1 Examples of Best Deals for Merchant and Customer
In Example 1, the Filet is the most expensive item, so it is the trigger. The Chicken Dinner is more expensive than the Spaghetti, so it is discounted by 50%. The total discount is $7.50.
In Example 2, the Filet is the most expensive item, so it is the trigger. The Spaghetti is the least expensive entree, so it is discounted by 50%. The total discount is $5.00.
Related Topics
