Simple Exclusivity
Table 15-8 Simple Exclusivity Options
| Option | Description |
9 - Simple Item Exclusivity |
When you select this option, only this discount can be applied to a menu item. This prevents individual items from being discounted more than once. Deselecting this option causes the Exclusivity Group settings to determine how this discount interacts with other discounts. If other discounts that are better deals can apply to the item or transaction, the better deal discounts apply. |
23 - Simple Transaction Exclusivity |
When you select this option, only this discount can be applied to a single check. This prevents the check from being discounted more than once. Deselecting this option causes the Exclusivity Group settings to determine how this discount interacts with other discounts. If other discounts that are better deals can apply to the item or transaction, the better deal discounts apply. |
24 - Discount is Final |
When you select this option, no additional discounts can be applied to the transaction after this discount posts. (This option works in automatic discount transactions only.) |
Related Topics
