System Employee Maintenance
The System Employee Maintenance module is designed for enterprises using Labor Management to configure employees needed for system transactions, such as Delivery Connectors, Simphony Transaction Services (STS), autofire, and table management systems. System Employee Maintenance is an abridged view of employee maintenance where employees can be set up outside of Labor Management as needed to associate with transactions typically not involving human interaction.
Simphony requires association of an employee with all transactions. System transactions are no exception. Because a person is not related to the system employee, there is no need to set up a person in Labor Management. Existing employees with no payroll ID are visible in System Employee Maintenance. You can add system employees as needed.
The System Employee Maintenance module shows only the fields needed to define a system employee.
Table 5-24 Basic Setup
| Hierarchy Access | Role Access | Role Privileges | Views |
Enterprise |
System Employee Maintenance |
Create, Edit, Read, Delete |
Table view, form view |
