42 Extension Applications
An Extension Application adds new operations by defining extension methods that are invoked using buttons created in the Page Design module. Existing operations are extended by implementing event handlers for workstation events. Extension methods and event handlers interact with the workstation using the Extension Application API.
The POS Client Extension Application API is the set of data types used by the Extension Application to interact with the workstation; this interaction includes the ability to add items to a guest check, prompt the user for information, invoke existing operations, evaluate configuration elements (such as employee options), and more.
