EMC Record Translation
In the EMC, you can translate the name of any record into multiple
languages using the Text Translation dialog. This dialog is invoked
by the Language Translation icon (
) on the
toolbar (or using the shortcut key F8). The Language Translation icon
only becomes active when a translatable text field or a translatable
table view cell is active in the module. This icon is dimmed if:
Only one language exists in the Enterprise
You do not have Edit access for the selected module
Translated text saves when the record itself is saved. Therefore, if you perform an undo operation on a record, record translations are also reverted.
Parent topic: Definition Translations
