Print Groups
Print groups are user-defined values used to sort menu items. Print
groups control sorting on various types of print jobs including order
chits, guest checks, and customer receipts. However, it is most commonly
used for order device output. You can use print groups to:
                        Sort by preparation time (items that take longer are sorted first)
                        Sort by meal course (appetizers before entrees)
                        Sort specific condiments last
                        Change the print group of parent menu items
Print groups are configured for a menu item class; new menu item class records are created with a default value of 1.
