Repeatable Menu Items
Repeat Round allows workstation operators to order several items (typically beverages or fixed price meal items) from the previous round of a guest check to the current round using a single button. Repeat Round is used when customers re-order the same menu items for another round. For example, a group of 10 people at the bar ordered 10 beverages. After drinking the beverages, they ordered another round. Rather than entering all 10 drinks again, the bartender presses the Repeat Round function key to quickly re-enter the beverage order.
If a menu item is set to check for availability, the Repeat Round function inquires and updates this status. If the availability of an item is exceeded, the entire Repeat Round process stops.
                        Weighed menu items
                        Combo meals
                        Voided and returned menu items
                        Menu items that are configured to allow a decimal amount entry
