21 Menu Item Waste
Menu Item Waste describes menu items that are not sold to customers due to reasons such as spillage, spoilage, and quality standards. Menu Item Waste also includes menu items that are donated (for example, to soup kitchens, employee parties, or used for photo shoots). There are three main characteristics of a menu item waste check:
  • Does not post to sales
  • Depletes inventory
  • Service Total and Print functions close a waste check
When menu item waste occurs, authorized workstation operators can begin a menu item waste check and then enter menu items to waste or donate. Managers can generate waste reports by revenue center, menu item, employee, and waste reason. Depending on the reasons for waste, managers can take action to reduce inventory loss. You can differentiate waste checks from other checks in the Employee Journal Report and the Check Journal Report by the Waste Check banner on the check header.
The following table lists the functional differences between menu item waste checks and guest checks.
Table 21-1 Differences Between Waste Checks and Guest Checks
Function Menu Item Waste Checks Guest Checks
Kitchen Display Systems (KDS) or screen lookups display the check
No
Yes
Reopen a closed check
No
Yes
Apply discounts
No
Yes
Apply taxes
No
Yes
Apply service charges
No
Yes
Apply guest count
No
Yes
Return item
No
Yes
Edit seat
No
Yes
Split check
No
Yes
Gift card or credit card operations
No
Yes
Send and Stay
No
Yes
Hold and Fire
No
Yes
Transaction void
No
Yes
Transaction return
No
Yes
Menu item availability
No
Yes
