Configuring OPERA Connection
  1. In the Interfaces module, create an interface record with the following settings:
    1. In the General tab, set the Interface Type to 6 - OPERA Connection.
    2. In the Options tab, set the following:
      Name
      This field is pre-populated with the System Name details and cannot be changed
      Auth Schema
      Select the schema from the drop-down list (SSD or OCIM)
      Enterprise ID
      Enter the Enterprise ID (OCIM only)
      Scope
      Enter the Scope (OCIM only)
      App Key
      Enter the App key
      Client ID
      Enter the Client ID (OCIM only)
      Client Secret
      Enter the Client Secret (OCIM only)
      User ID
      Enter the User ID (SSD only)
      Password
      Enter the Password (SSD only)
      URL
      Enter the URL
      Maximum Number of Results
      Enter the maximum number of search results. Leave blank to allow up to 20 results.
      For more information on how to obtain these details, see the Oracle Restaurants Integration Platform User Guide.
    3. In the Properties tab, select one or more properties where the Connection will be enabled.
  2. In the Properties Parameters module, configure the OPERA Property Parameters. For each property selected in the previous step, you must configure one or more OPERA property parameters.
    1. In the General tab under the OPERA Property Parameters section, set the following:
      OPERA Connection
      Select the OPERA Connection from the drop-down list
      Hotel/Resort ID
      Enter the Hotel or Resort ID for the OPERA property
      The Hotel or Resort ID is case sensitive, and needs to be capitalized.
      Currency Code
      Select the Currency Code for the base currency of the OPERA property
      Cashier ID
      Enter the Cashier ID for this OPERA property
      Posting Type
      Select Sales Itemizers to post sales to OPERA by Sales Itemizers, or Family Groups to post sales by Family Groups
      External System
      Enter the name of the External System in OPERA
      For more information on how to obtain these details, see the Oracle Hospitality Integration Platform User Guide.
    2. Check the configuration by pressing the Validate button.
    3. In the Options tab, select option 65 - Activate OPERA Connection. This step is required for clients to obtain security tokens and for non-room charge transactions to be posted to OPERA. It is recommended to complete the remaining steps prior to activating the connection.
  3. In the RVC Parameters module, enable the OPERA Connection in the Interfaces tab. The OPERA PMS Interface must be enabled for each revenue center that uses OPERA.
  4. For Self Pay only, see Configuring the OPERA PMS Payment Driver.
  5. In the Tender/Media module, configure the tender based on the OPERA Connection posting type that you require:
    1. Configure a Room Charge tender to post a guest's check to the OPERA room folio.
      1. Configure the Room Charge tender with the Interface Link that corresponds with OPERA Connection.
        Do not select the Interface Link for OPERA Self Pay tenders.
      2. Optional: To print OPERA tender-reference information, such as the guest name and room number, select 100 - Print Tender Reference of OPERA Connection on Guest Checks and Customer Receipts.
    2. Configure an Accounts Receivable tender to post a check to an OPERA AR account, such as an officer or company account.
      1. On the General tab, in the OPERA Connection PM/AR Account field, enter one of the following values:
        • AR:<account-number> to post to a specific OPERA AR account.
        • AR: to prompt the operator to enter the AR account when applying the tender.
      2. On the Interface Options tab, select the Interface Link that corresponds with OPERA Connection.
      Operators must enter the exact AR account number. Simphony does not provide account-name lookup or selection. If only part of the check is paid using the AR tender, Simphony prorates the related discounts, sales itemizers, and service charges.
      Use the AR: prefix only for Accounts Receivable tenders. Do not use it for Room Charge, General Ledger, or OPERA Self Pay tenders.
    3. Configure a General Ledger tender to post a payment already received in Simphony, such as a cash or card payment, to an OPERA Payment Master account for centralized reporting.
      1. On the General tab, in the OPERA Connection PM/AR Account field, enter the OPERA Payment Master account.
      3. Optional: To post the payment with the sales and automatically settle the OPERA transaction to 0.00, enter the OPERA payment-method code in the Auto-balance Payment Method field.
      4. You can configure OPERA Connection to post the payment with the sales to the Posting Master (PM) account, automatically settling the transaction to 0.00. This is typically used for credit card or gift card tenders. Obtain the payment-method code configured in OPERA.
        1. On the General tab, enter the code for the payment method in the Auto-balance Payment Method field as configured in OPERA.
  6. In the Page Design module, configure the following buttons:
    1. Add a Room Charge button to the touchscreen with the following settings:
      Type
      Payment Tenders (select the tender created in Step 5a)
      Payment Type
      Cash:Cash
    2. Add an Accounts Receivable Tender button to the touchscreen with the following settings:
      Type
      Payment Tenders (select the tender created in Step 5b)
      Payment Type
      Cash:Cash
    3. Add a Guest Lookup button to the touchscreen with the following setting:
      Type
      Pms Inquire (select the corresponding Interface link)
    4. (Optional) Add a Begin Check By… button to the touchscreen with the following settings:
      Type
      OPERA Connection Configuration – Configuration Details:
      Type
      Begin Check
      Command
      Select the desired “Check by” option (Name, Number, Table).
    5. Add an OPERA Self Pay button to the touchscreen with the following settings:
      Type
      OPERA Self Pay
      OPERA Self Pay Configuration
      Options
      1. Select Exit Opera Self Pay Without ID Prompt when OPERA Self Pay is used on a guest-facing device (such as a kiosk). This allows the guest to exit to the order screen without employee intervention.
      2. Select Hide Email Prompt Screen to not prompt for an email address. If this option is disabled, the guest is prompted for their email address.
      3. Select Enable Tip Screen, and then enter the Default Tip Percent value between 0 and 99. This tip percentage value is shown to the guest. For handheld devices, configure suggested tips in Order Type Parameters.
      4. Select Mask Account Data on Entry so that OPERA Self Pay masks all but the most recently entered character. Guests can use the eye icon to view the complete entry. The information is also masked on the signature screen, and check details are omitted from the protected payment-confirmation screen.
      Select Payment Method
      1. In the Select Payment Methods section, select Opera as the payment type from the Type drop-down list.
      2. Click the Edit... link in the Command column.
        Payment Type
        Other1:LoadablePms
        Interface
        Select the Interface record.
        Tender Media
        Select the Room Charge tender.
        Legend
        Enter the payment method name. If multiple payment methods are configured for Self Pay, the guest can select the payment method by this name.
      3. Click OK.
      4. Check the Enabled box.
      5. Click Ok to save the Select Payment Methods configuration.
