OPI Architecture
In the Simphony implementation, an OPI server is installed on-premise and processes payment requests between the Simphony workstations and the PSP. The PSP provides the PIN Entry Devices (PEDs) that read and process credit card data, and then communicate with the PSP Host on the Cloud. The PEDs can be connected directly to the workstations (usually via serial, USB, or Bluetooth connection) or they can be network devices.
OPI supports two modes:
  • Terminal Mode
  • Middleware Mode
In Terminal mode, the OPI Datastore database contains a table with a one-to-one mapping of workstation to PED. A payment request from a workstation is directed to the correct PED. In Middleware mode, the PSP provides an application, called middleware, that handles the mapping of a workstation to a PED. The OPI server directs all payment requests to the middleware application, which then routes the request to the appropriate PED. In either mode, neither the OPI server nor Simphony come in contact with credit card data. Sensitive data is handled strictly between the PED or middleware and the PSP Host. OPI receives and stores tokens and voucher printing instructions from the PSP, and passes the voucher data to Simphony, leaving Simphony and the OPI server out of PA-DSS scope.
Figure 11-8 Terminal Mode Architecture
This figure shows the Simphony OPI architecture using Terminal Mode.
Figure 11-9 Middleware Mode Architecture
This figure shows the Simphony OPI architecture using Middleware Mode.
